Latest: DanDan17
Overall: 17128
Online Now [364]:
Visitors: 363
Today: 18095
Total: 100687503
Forums › The Car › 206 Problems › MAF sensor
MAF sensor
206Mike
PostPosted: Thu Jan 12, 2012 4:31 am Up
Are all MAF sensors the same?
I expect there to be a difference RE. Petrol & Diesel (Do diesels even have a MAF sensor?) but in the petrol trim are they the same for each engine size or is there a different MAF sensor for each engine?
Yes i am a noob Sad
+8 Pos feedback Smile
Rob2859
PostPosted: Thu Jan 12, 2012 7:43 am Up
Not sure about the 2.0 but the TU petrols have MAP sensors not MAFs.
D4NTP
PostPosted: Thu Jan 12, 2012 8:03 am Up
GTI has a MAP sensor.
gixxerkev
PostPosted: Thu Jan 12, 2012 8:59 am Up
MAP sensors for the TU range of engines are different, I bought one from eBay and it a 3 pin plug instead of a 4 pin plug, sent it back and got the correct one though (the sellers item description was incorrect). If you need a new one check the part number on the old one before you buy and I did a soft BSI reset after I'd fitted the new one.
An Ex '03 1.4 GLX driver, German technology all the way now.
206Mike
PostPosted: Thu Jan 12, 2012 11:33 am Up
Does each engine size have a different MAF/MAP with a different part number? Also where abouts is it in the engine bay? Near your airbox?
PostPosted: Thu Jan 12, 2012 11:36 am Up
MAF is on the airbox, MAP is usually on the intake
The engine you have will be helpful Confused
206Mike
PostPosted: Thu Jan 12, 2012 11:38 am Up
Lmao sorry, 1.4 8v.
Whats the difference between MAF and MAP unless they perform the same function on a different engine?
PostPosted: Thu Jan 12, 2012 11:41 am Up
www.enginebasics.com/E...20MAF.html
PostPosted: Thu Jan 12, 2012 11:51 am Up
MAP
Peugeot/Citroen = 1920 0E or 1920 9H
Fiat/Lancia = 9618261580
Bosch = 96 182 615
206 1.1, 1.4 and 1.6....all 8v
206Mike
PostPosted: Thu Jan 12, 2012 4:27 pm Up
Lee. I love you. Let me bear your children.
