Latest: DanDan17
Overall: 17128
Online Now [305]:
Visitors: 304
Today: 50585
Total: 100650952
Forums › The Car › 206 Problems › car keeps cutting out
loudnproud
PostPosted: Wed Jan 18, 2012 7:26 am Up
hi,my 03 plate 206 1.4 petrol suddenly cut out yesterday while driving and now refuses to run,it will start sometimes but only for a minute or two,as soon as i touch the accelerator it cuts out,have had it plugged in no codes come up,the fuel pump is priming and there is a new battery on, please help i need my car back on road asap, thankyou in advance
gixxerkev
PostPosted: Wed Jan 18, 2012 11:46 am Up
Pretty much the same happened to me today. Mine lurched after every gear change and died when I dipped the clutch. It would start for a couple of mins then die if I touched the gas peda.l I read the codes and it was the MAP sensor, replaced it and everything is fine now.
Hope this helps.
An Ex '03 1.4 GLX driver, German technology all the way now.
loudnproud
PostPosted: Thu Jan 19, 2012 3:36 pm Up
still not running Sad
john206gti
PostPosted: Fri Jan 20, 2012 11:45 am Up
have a look at the battery earth cable. where it bolts on top of the gearbox
check its not snapped/frayed
2001 moonstone gti, gt bumpers, gen2 k&n induction kit, lightened flywheel, lowered 35mm,
loudnproud
PostPosted: Fri Jan 20, 2012 1:06 pm Up
checked all earth straps still not running, anyone know what`s wrong with it ???
dtm_martin24
PostPosted: Fri Jan 20, 2012 6:10 pm Up
Check the lambda sensor, wouldn't have thought it would cause this but my 306 had a very similar issue and when i changed it, it's running has improved and it no longer stalls
Peugeot 206 1.4 HDI Style 3dr
loudnproud
PostPosted: Sat Jan 21, 2012 1:53 pm Up
checked lamba starting to give in and looking for another car :/
PostPosted: Sat Jan 21, 2012 1:58 pm Up
fuel filter?
loudnproud
PostPosted: Sat Jan 21, 2012 2:00 pm Up
checked mate even paid to have plugged in again 1 unknown fault Sad
PostPosted: Mon Jan 23, 2012 4:48 pm Up
Crank position sensor - cheap if you can do it yourself?
Coil pack - bit more expensive?
Lambda will not prevent starting or driving but will light the engine warning light.
