Posted: Wed Jan 18, 2012 1:48 pm |
Hi
The missus had got a 206 with a crappy al4 gearbox, it keeps flashing the ice and sports buttons and goes into limp mode.
Now I'm going to get her a new gearbox off the warranty but is there anyway I can stop the car going into limp mode?
Or stop it from flashing the sport and snow button as it very annoying.
I know it needs fixing but I will get around to it eventually, I know you can restart the car and restarts the sensors but is there any other solutions?
Posted: Wed Jan 18, 2012 1:57 pm |
Not until you fix the gearbox. The ECU is trying to prevent things getting worse. Is it a Peugeot warranty?
Posted: Wed Jan 18, 2012 2:02 pm |
Cheers mate.
No its aftersales warranty mate when my missus bought the car.
Posted: Wed Jan 18, 2012 2:06 pm |
| Quote:: |
The (AL4) autoadaptive automatic gearbox is lubricated for life .
All that is required is an oil level check at 60000 km .
Despite that, the automatic gearbox has a system for measuring oil quality .
The AL4 autoadaptive automatic gearbox ECU has an oil wear sensor .
For a given time interval, the counter increases by a certain number of units (of wear) depending on the temperature of the gearbox .
When the counter is exhausted, the gearbox ECU informs the driver of the presence of a fault by the flashing of the Sport and Snow indicator lights on the instrument panel .
Using the diagnostic equipment, the technician checks whether or not it is necessary to replace the gearbox oil . |
Posted: Wed Jan 18, 2012 2:41 pm |
Thanks for that but thats not the only reason why the ice and snow buttons flash.
Posted: Wed Jan 18, 2012 3:54 pm |
What mileage is yours at. I would say it wouldnt do any harm chaging gearbox oil anyway.
Posted: Wed Jan 18, 2012 4:26 pm |
Its 68,000 miles, changed it but still flashes mate.
Posted: Wed Jan 18, 2012 4:52 pm |
| scottishdave wrote: |
| Its 68,000 miles, changed it but still flashes mate. |
Same gearbox, same mileage here
I dont think you'll be able to stop it from going into Limp mode. You'll need to get the codes read first to find out what the cause is.
