Latest: elelectricistadeMateo
Overall: 17127
Online Now [50]:
Visitors: 49
Today: 23701
Total: 100396377
Forums › The Car › 206 Problems › 2001 206 gti dashboard lights.
m4tth3w
PostPosted: Thu Jan 19, 2012 3:34 pm Up
One of lights has gone behind clocks
How do you replace the bulb?
Is there any chance it could be a fuse.
PostPosted: Fri Jan 20, 2012 6:18 am Up
Just remove the cowling and stick a new bulb in...
oldskoolz
PostPosted: Fri Jan 20, 2012 6:36 am Up
lift off cowling (cover) 1 torx screw at top of speedo, pull out, change bulb, refit
Black 206 Gti. Soon to be 2.2
m4tth3w
PostPosted: Fri Jan 20, 2012 5:17 pm Up
Don't want to sound thick but how does the cowling come off? Where do you push and pull?
Thanks.
PostPosted: Fri Jan 20, 2012 5:18 pm Up
Just pull it off
