Posted: Sat Jan 28, 2012 9:52 pm |
Trade Rating: +16
As above, today I noticed that when I press the brake light, not only the do all three brake lights come on but so does my off side, side light.
when the lights are on and I press the brake the side lights is fine.
My side lights are l.e.d but it's the first time ive noticed this odd side light trick.
Posted: Sun Jan 29, 2012 2:05 am |
poor earth to the off side cluster brake light is using the side light for a earth. clean up connections and double check the fitment of bulbs.
Posted: Sun Jan 29, 2012 4:37 am |
parkesie wrote: |
poor earth to the off side cluster brake light is using the side light for a earth. clean up connections and double check the fitment of bulbs. |
i would have to agree with this, also what lights are they?
Posted: Sun Jan 29, 2012 5:53 am |
I had a similar problem with my CC when it had Lexus Lights.
The problem with mine was a loose wire on the where the lights plugged into the car.
Problem solved by connecting the wire properly.
Posted: Sun Jan 29, 2012 6:41 am |
Also happened to me when I replaced the brake light bulb with the wrong type of bulb.
Posted: Sun Jan 29, 2012 7:59 am |
Trade Rating: +16
Thanks for the replies guys..
Will see if any of your suggestions fix this..
Posted: Sun Jan 29, 2012 8:05 am |
i would say wrong type of bulb, eg a double filament in a single filament holder
