Online Now [150]:
Visitors: 149
Today: 1379
Total: 117043107
Forums › The Car › Request a how-to › How can I run the engine cooling fan
Forum IndexRequest a how-to
alaakaleel
PostPosted: Wed Apr 18, 2012 2:56 am Reply with quote Up
How can I run the engine cooling fan at a temperature of 75 or 80 degrees in a car Peugeot 206
Alaa Khalil
snowonfire
PostPosted: Wed Apr 18, 2012 3:15 am Reply with quote Up
Your a bit unclear on what you are looking for here...
Can you explain what you are trying to do?
Are you testing the fan?
Is the fan broken and you're looking for a fix?
Big_Rich180
PostPosted: Wed Apr 18, 2012 3:19 am Reply with quote Up
I think he's wanting the fan to cut in at 75-80 deg.
Im not sure how you would do that but I think you could get the fan hooked up to a button and that way you could turn it on when you like.
PostPosted: Wed Apr 18, 2012 3:40 am Reply with quote Up
Im not sure why you'd want to do that, but unless you can get a cut in switch that operates at that temp or adapt one, a manual switch is the only way.
PostPosted: Wed Apr 18, 2012 4:14 am Reply with quote Up
just use the switch in the diesel version.
they kick in at 80degree
PostPosted: Wed Apr 18, 2012 5:27 am Reply with quote Up
The switch is the ECU though.
PostPosted: Wed Apr 18, 2012 9:18 am Reply with quote Up
Seeing as the OP is based in Iraq which is a much hotter climate during the daytime then the UK I would be looking to fit a better spec of radiator for more cooling then trying to make the fan cut in earlier.
alaakaleel
PostPosted: Thu Apr 19, 2012 12:02 am Reply with quote Up
my fan it works OK but I need to change started work at 75 or 80 by change the Programming mind of the car.
can I do it ?
Alaa Khalil
craigdmjv
PostPosted: Thu Apr 19, 2012 12:47 am Reply with quote Up
i know how to sort of do it on a cinquecento if that helps lol
PostPosted: Thu Apr 19, 2012 8:19 am Reply with quote Up
can I do it ?
No point running the cooling fan at anything less then 89 deg C as the thermostat will be shut & there will be no coolant flow from the engine through the radiator.
Until the thermostat opens to allow the hot coolant to flow in to the radiator, it & the cooling fan are basically not doing anything to aid engine cooling.
Ash
PostPosted: Thu Apr 19, 2012 10:50 am Reply with quote Up
Is it always warm in Iraq?
Remove the Thermo and hard wire the fan to a switched live Laughing
PostPosted: Thu Apr 19, 2012 11:01 am Reply with quote Up
A better spec of radiator is whats needed here Wink
Ash
PostPosted: Thu Apr 19, 2012 4:51 pm Reply with quote Up
I didn't expect anyone to take my reply seriously Laughing
alaakaleel
PostPosted: Thu Apr 26, 2012 5:16 am Reply with quote Up
I put temperature sensor Mercedes car running at 85 degrees have become good
thanks for answer
Alaa Khalil
  Quick Reply
Username:
Message:
Quote the last message
