Posted: Tue Jan 24, 2012 10:08 am |
hi.
started this morning. got to work, turned car off, took key out then a clicking sound from the fuse board inside the car (sounds like a relay), and with the clicks the battery light and info screen on the dash come on. when its doing it the central locking is inoperable.
it does it for between a few seconds and a few minutes, then seems to stop, allowing me to lock the car.
any ideas?
thanks
si
| Peugeot 206cc SPL build
2011 - 2 vibe 12" spaces, 38hz ported box, 2.5k Ground zero Nuclear mono - 141.2db @ 38hz
2012 - GZ Nuclear 12"s, 33hz box, 2 x 2.5k GZ Nuclear monos, 8" GZ comp mids, 4" GZ tweeters - 144.0db @40hz off 1500wrms
build thread -http://www.206info.co.uk/Forums/viewtopic/p=486554.html#4865540 | |
Posted: Tue Jan 24, 2012 11:28 am |
sorted. ariels been leaking and filled the interior light.
disconnect the light and its problem solved
Posted: Tue Jan 24, 2012 1:44 pm |
Glad you got it sorted,you had a short circuit cuz of water,get a new anttena base from Ebay or dealer it cost about 6GBP or so,because water inside the car is never good.
Posted: Tue Jan 24, 2012 4:15 pm |
Ordered this morning
Posted: Thu Jan 26, 2012 12:23 pm |
simon_p wrote: |
Ordered this morning |
