Latest: KevinRC
Overall: 17137
Online Now [253]:
Visitors: 252
Today: 507
Total: 111142095
Forums › The Car › Solved 206 Problems › 206 boot lid change has
nellyhaggis
PostPosted: Tue Jan 24, 2012 9:18 am Up
Has anyone changed the boot lid on a 206 before?
If so how did you get on with disconnecting the wires without cutting them?
Cheers.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
Abzynthe
PostPosted: Tue Jan 24, 2012 9:45 am Up
East Area Rep - Abzynthe
I've done it a few times. Its easy, you just need to disconnect the wires from the loom from behind the side carpet panel on the left in the boot and unbolt the earth cable from nearly the same place. Thread it through the hole in the roof near the boot hinges. Once thats done, unbold the hinges and left away.
Pretty much the same to put back on.
