Online Now [691]:
Visitors: 691
Today: 23458
Total: 142406294
Forums › The Car › 206 Talk › Upgrading the Air Con
jonathonccs
PostPosted: Tue Feb 07, 2012 3:39 pm Up
I have a 1999 1.4 206. And I have air conditioning.
This one..............
But I'm wanting to upgrade to this one........
I know there must be a lot of work to do this, but I was wondering what work that is.
Has anyone done this before or does anyone know what needs to be done?
JJ
PostPosted: Tue Feb 07, 2012 3:45 pm Up
Its been done lots of times in the past BUT its a right pain to do due to the many differences between manual aircon & climate control.
PostPosted: Tue Feb 07, 2012 3:47 pm Up
I was one of the first, good but pointless mod
And fair amount of work too
Martind
PostPosted: Tue Feb 07, 2012 4:28 pm Up
I know it is a little unecessary to ask....
Why do you want Climate Control over A/C anyway?
I have a GTI so has Climate as standard and it annoys me..... It has either ECO or A/C settings.
Because I am a cheapskate, I am a little paranoid about it using excessive fuel when it is on, but there isn't a way (That I know of) of ensuring the A/C is completley off unless you switch the whole unit off, but then you get no air coming out of any of the vents.
I would prefer Manual A/C myself.
Like I say, I know it is just me being a cheapskate. But I would have liked an A/C OFF setting!
PostPosted: Tue Feb 07, 2012 4:36 pm Up
I just leave my climate control on AUTO all the time.
Aircon on a modern car uses less fuel then opening a window.
Martind
PostPosted: Tue Feb 07, 2012 4:50 pm Up
I agree with the second part.
(I was thinking that TopGear should test that)
Also stops the buffering, and actually keeps you cool on a hot day unlike a window open.
Like I said, it is just me being paranoid.... Purely because I am a cheapskate.
I'm not the type to drive with my window open thinking I am saving by not using the A/C
I have mine set to ECO, vents on either Screen and Footwell, or just Footwell.
PostPosted: Tue Feb 07, 2012 4:57 pm Up
I just leave it on AUTO & adjust the temp if / when it needs it.
For the small amount of extra fuel it uses, you cant really be that tight!
Martind
PostPosted: Tue Feb 07, 2012 5:02 pm Up
I don't know.... It is just something about it not being in ECO.
It isn't because I am that tight, because the car is going to use what it uses.
My brain knows that it isn't going to all of a sudden turn into a Hummer H2, I know the difference isn't going to be noticable really...
Just something in me that makes me put it on ECO, unless I need it on Full A/C
I can't be the only one... Surely?
Ash
PostPosted: Tue Feb 07, 2012 5:08 pm Up
Why don't you drive a 1.1 then?
Martind
PostPosted: Tue Feb 07, 2012 5:12 pm Up
There isn't a great deal of differance in the MPG figures (realisticly) between them.
Figures say there is quite a bit, but even on here realisticly there isn't a lot in it.
I think people may be missing my point a bit though.
Plus, where I live, there are a lot of fast roads and steep hills.
Anything less than 1.4 is just not powerful enough.
With a smaller engine, you are constantly changing up and down gears to try and keep momentum and just having to rev and rev to keep up with the traffic
jonathonccs
PostPosted: Tue Feb 07, 2012 5:35 pm Up
I'm not really bother about fuel consumption. It's not going to use that much more. I was wondering What needed to be done to make this change?
JJ
Martind
PostPosted: Tue Feb 07, 2012 5:40 pm Up
That wasn't really the point I was getting at so much.
I was mainly asking why you were thinking about it? I don't see so much benefit of Climate over A/C, other than you get to choose your temprature.
jonathonccs
PostPosted: Tue Feb 07, 2012 5:42 pm Up
Because I want to choose my temprature Very Happy
JJ
Martind
PostPosted: Tue Feb 07, 2012 5:44 pm Up
Is that all?
It does look a bit fancier in the dash, I must say.
And you do get 8 fan speeds, rather than 4.
jonathonccs
PostPosted: Tue Feb 07, 2012 5:49 pm Up
It's just better all round than the standard crap I have. But just not sure how to go about it? What would I need?
JJ
