Latest: Flyin180
Overall: 17116
Online Now [28]:
Visitors: 27
Today: 36115
Total: 95175365
Forums › The Car › 206 Talk › Wheel nuts question
Wheel nuts question
skinny
PostPosted: Tue Feb 14, 2012 10:11 pm Up
I'm looking at doing a stud conversion and wondered whether I would need flat nuts for my wheels or whether tapered would be good enough on the alloys, the holes are flat themselves though so I'm guessing I need the flat nuts also.
Pug 206 1.4 Hdi
Pug 206 Gti 138
meady
PostPosted: Wed Feb 15, 2012 2:24 am Up
Trade Rating: +45
Yeh if they are flat then you need flat seated nuts Smile
TEAM - I HATE FACEBOOK Smile
PostPosted: Wed Feb 15, 2012 9:58 am Up
there's nothing wrong with the design of the standard wheel bolts.
skinny
PostPosted: Wed Feb 15, 2012 2:29 pm Up
I didn't say there was anything wrong, just that if I am to put spacers on then I will need longer bolts and I would find it easier and different to go for a stud conversion instead
Pug 206 1.4 Hdi
Pug 206 Gti 138
PostPosted: Wed Feb 15, 2012 2:38 pm Up
Its just easier to get wheels that fit a 206.
PostPosted: Wed Feb 15, 2012 4:07 pm Up
word of warning, do not use grayston stud or any cheap ebay stud.
you will regret; the thread will be damage easily. This is not the first time i have seen this happen.
and even when they are new, their thread is not clean! Most peugeot trackday boys know this long time ago....
however, decent stud will cost you an arm and a leg, unless you machine it yourself
skinny
PostPosted: Thu Feb 16, 2012 4:15 pm Up
They do fit a 206 properly, it's the same with my Atlantis rims and coilovers. Still need spacers on the front.
Really Seabook?
So these won't be any good?
Item: 290519508697 on eBay
Pug 206 1.4 Hdi
Pug 206 Gti 138
PostPosted: Thu Feb 16, 2012 4:21 pm Up
those are exactly the stuff you need to avoid.
PostPosted: Thu Feb 16, 2012 4:25 pm Up
i got a set 1 yr ago, 16 stud, 4 of them jammed on the wheel nuts; so i have to order another 4 to get it to work.
and you can feel by hand the thread is not clean cut, not to mention they aren't high tensile steel.
Macj run those stud on his rally car and in the last event i think one of the stud was damaged and causing wheel vibration.
skinny
PostPosted: Fri Feb 17, 2012 1:56 pm Up
But on the description it says they are high tensile :/
Pug 206 1.4 Hdi
Pug 206 Gti 138
gazza82
PostPosted: Fri Feb 17, 2012 2:14 pm Up
But it's also fleabay! Wink
PostPosted: Fri Feb 17, 2012 2:58 pm Up
if they are high tensile they should state what grade they are, plus for
grayston stud they never said they are high tensile, they are just normal zinc plate carbon steel (unknown grade so it has to be below Cool
And for that kind of price i would expect they are grayston stud (around 1 quid each)
and to be fair, you don't want to put cheap stud+nut to hold your wheels; although it is not the first time i have seen people's wheel coming off from the car in the corner Laughing Laughing Laughing Laughing
