Online Now [1419]:
Visitors: 1419
Today: 166235
Total: 150763779
Forums › The Car › 206 Problems › DV4 1.4 HDI engine/gearbox mount
Antknee
PostPosted: Fri Jan 20, 2012 10:47 am Up
I believe the engine mount needs replacing as the gearbox has become pretty shaky
Which part do i need to replace?
One or both of these on servicebox:
0000181347
0000184451
or is this the one?
www.ebay.co.uk/itm/RIG...917wt_1185
Or there are a few on euro car parts but i'm not sure which is the right one and what parts are required to change
cheers for any info!
Antknee
PostPosted: Tue Jan 31, 2012 1:53 pm Up
bump
PostPosted: Tue Jan 31, 2012 2:00 pm Up
all MA box in 206 share the same set of engine mounts.
so they are all interchangeable
at work at the moment so can't check what are 0000181347 and 0000184451 (but i presume is the lower and left mount), the one in your ebay link is right mount (under the ECU)
if you want to know which mount is broken you better jack up the car and check, should be quite easy to tell if they are damaged
but i would check the lower mount and left mount(gearbox) first.
Antknee
PostPosted: Tue Jan 31, 2012 6:36 pm Up
Cheers mate i was getting them the wrong way round lol i was thinking the gearbox mount was right (not left) one! lol cheers
