Online Now [48]:
Visitors: 47
Today: 55000
Total: 117304894
Forums › The Car › 206 Problems › 180 oil leak, Thermostat housing, Crankshaft seal?
sri16v
PostPosted: Mon Jan 30, 2012 4:56 pm Up
Ive got a bit of an oil leak on my 180, the oil seems to be sitting on top of the gearbox, I cant see where its leaking from at present as I havent had time to strip it down and look, but I know for sure its not coming from the cam covers.
Are there any common areas where they leak aside from the cam cover?, or could it be a split breather pipe from the top of the cylinder head?.
2004 GTi 180
PostPosted: Mon Jan 30, 2012 5:34 pm Up
will be rocker cover gaskets had this on my 180 common fault and cheap and easy to fix
remove engine cover and then there's just 20 or so bolts holding down the two rocker covers swap the rubber gaskets over and refit job done Smile
Big_Rich180
PostPosted: Tue Jan 31, 2012 5:19 am Up
What She Said
sri16v
PostPosted: Tue Jan 31, 2012 1:12 pm Up
Im guessing the leak is coming from behind the block, out of site then?, as I replaced the gaskets when I first got the car, which was nearly 3 years ago, oh well if its a cheap fix im happy, was dreading the thought of removing the gearbox again on the ground if it was the CS seal Very Happy
2004 GTi 180
gpvecchi
PostPosted: Tue Jan 31, 2012 3:28 pm Up
If oil is ON TOP of gearbox, it surely doesn't come from the inside, unless you park your car wheels up...
I replaced rocker cover gasket on mine too, but there was a great oil leakage from cammes position sensor (it's about under the thermostatic valve).
I think that's your problem, oil flooded on top of gearbox. Obviously, Pug doesn't sell just the O-Ring, you need to buy the whole sensor...
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
