Online Now [619]:
Visitors: 619
Today: 242276
Total: 146697140
Forums › The Car › 206 Talk › Removing Airbox parts
Forum Index › 206 Talk
james180
PostPosted: Tue Jan 31, 2012 11:21 am Up
My 180 came with a pipercross cone filter and i didnt get the standard airbox. Sad
Was going to fit some ducting to it and remove the bottom part of the original airbox parts but it is connected to a few other parts and i dont know what they are?
One is an electrical switch type thing next to the battery box with two small vaccum pipes going to something round?
The second thing is some sort of pump i think above the passenger side foglight?
Does anyone know what these are and am i ok to remove all of this?
Understeer is a crime.
Andy180
PostPosted: Tue Jan 31, 2012 12:42 pm Up
Chuck the cone filter in the bin and put the original airbox back on.
GTI 180
james180
PostPosted: Tue Jan 31, 2012 12:52 pm Up
Havent got the original airbox. And why would i chuck it in the bin even if i did when i could sell it?
Andy180
PostPosted: Tue Jan 31, 2012 12:59 pm Up
Because there crap and lose power the original setup is the best.
GTI 180
james180
PostPosted: Tue Jan 31, 2012 1:21 pm Up
Didnt ask if the cone filter was any good or not so dont really care if it does loose a bit of power because it sounds nice.
Does anyone know anything about the parts i asked about?
drunknmunky
PostPosted: Tue Jan 31, 2012 1:26 pm Up
yeah i do i ripped them all out of mine and got an anti pollution fault Sad the pump is a secondary air pump and costs a lot of money and once unplugged will cause the fault!
the smaller pipes lead up to the engine breather and the box at the bottom is a catch/ recirculation box
to put it simply it reuses what would be waste by sending it back through the engine breather pipes down to the air intake and puts a bit of it in with the air from the duct under the wing each time so as not to put gases into the atmosphere and so on
there's also a throttle on the bottom pipe which opens at a certain time to allow more air its quite a complex and good system which is why its recommended not to remove it just find an original airbox and put a panel filter in will still sound good and perform better.
james180
PostPosted: Tue Jan 31, 2012 1:36 pm Up
Thanks mate thats exactly what i was after.
drunknmunky
PostPosted: Tue Jan 31, 2012 1:54 pm Up
no problem Smile
