Latest: DanDan17
Overall: 17128
Online Now [79]:
Visitors: 77
Members: 1
Today: 17504
Total: 100415685
Forums › The Car › 206 Problems › Hdi vibration rattle
Fifer
PostPosted: Tue Jan 31, 2012 1:56 pm Up
Hi again all
My hdi engine vibrates at idle with the metal pipe (aircon ?) at the front top shaking about, is this normal?
Also the car seems to have a rattle/noise at low revs that disappears as the revs build usually about 2300 to 3000 rpm and goes silent (well as much as a diesel can). It doesn't seem to be coming from the pulley are though. Again is this normal or does anybody have any ideas I can check.
In the meantime it's axle bearing change time this weekend.
1.4hdi 02
ruski
PostPosted: Sat Feb 04, 2012 11:50 am Up
crank pulley common fault
r.smith
Fifer
PostPosted: Sun Feb 05, 2012 12:20 pm Up
Thanks. Doesn't seem to be the pulley and after searching all threads it may be an injector. I'm running bg 244k through it at the moment.
For the future as I may change the pulley anyway, is it the timing crank pulley ( that the timing belt runs off) or is it the accessory pulley.
1.4hdi 02
skard
PostPosted: Sun Feb 05, 2012 2:25 pm Up
the big pulley at the bottom of the aux belt.
on my 1.4hdi i had a rumble at tickover and it was the alternator pulley (belt tensioner was bouncing).
Fifer
PostPosted: Sun Feb 05, 2012 3:18 pm Up
I will have another check of pulleys this week. Just sprayed a bit of grease on the pulleys and it now seems to be just engine noise ( no rattle) I won't really know till tomm though.
1.4hdi 02
