Posted: Thu Sep 17, 2015 3:52 am |
Hi, what did you decide to do about the balancer shafts?
| 114.3 - 180bhp 1.9 8v (depends which readout you believe)
Ew hybrid in progress... | |
Posted: Fri Sep 25, 2015 4:27 pm |
=ZiAn= wrote: |
@Usher, when the mechanics get it all together Should be in about a month or two as they a re a bit busy... But if I've waited for the last 4 years I can wait a few months more
@206gt160, 15" Citroen c5 if I'm not mistaken and they were super light (don't quote me but i believe they were around 6kg?).I'll ask the owner of the wheels when I get to see him | Around 4.6kg more precisely Need another set? I have like 4 sets
vxedcc wrote: |
Hi, what did you decide to do about the balancer shafts? | We threw them out as they are not needed.
Posted: Sat Sep 26, 2015 3:13 am |
how much power it running, is 2.2 more worth to put rather than gti180 engine :),
Posted: Sun Sep 27, 2015 2:53 pm |
Not built yet. It will have a gti180 head with catcams 805. More potential with bigger displacement, but we will see.
Posted: Tue Oct 20, 2015 3:22 pm |
Posted: Sat Nov 07, 2015 6:35 am |
Thanks for the update Drmo I haven't had a lot of time lately, so I haven't been posting much so here are a few more pics:
Posted: Sat Feb 13, 2016 3:40 am |
Posted: Sat Feb 13, 2016 9:17 am |
Excellent. I'm surprised you still have the air conditioning pump still in there. Would be interesting to see how the EW12 likes to rev with it being a longer stroke than the EW10.
Posted: Wed Feb 24, 2016 8:56 am |
I've had mine in for sometime now BTW, did you notch your pistons for valve clearance, the valves on the 180 open more than the ew12s. I did on mine but I also kept the balancing shafts,
Posted: Wed Feb 24, 2016 8:57 am |
No egr on mine either as I'm still using gti180 ECU
Posted: Mon Mar 14, 2016 3:46 am |
I Timed the cams in a way that there is enough clearance when the cam is fully advanced so no notching the pistons needed. The cams are Catcams 4901805, so much more lift than the original GTI180 cams. The springs and retainers are also from Catcams.
The Balancing shafts were deleted because the rev limit will be higher and there is possibility of oil starvation and balancing shaft seizing.
@tRiCk: did you get it remaped or at least on a rolling road?
Posted: Thu May 05, 2016 3:02 pm |
So things are moving along, the engine is in the car and should be getting the new loom, ECU and tune in the following weeks.
Here's also a short video from last years track session. Had to slow down in the middle, due to a "funny" feeling in the steering though it luckily turned out to be fine
www.youtube.com/watch?v=JsQfc8j51ls
Posted: Fri May 06, 2016 6:14 pm |
Thanks for the vid! Will serve me as a benchmark to hit of a well balanced rebuilt engine -- you gotta hear those 16 valves purrrrrroaring!
What was that steering wheel feeling out of interest?
Posted: Sun May 08, 2016 3:28 am |
It was like driving on gravel etc. It's been a while since the last time I was out on track and forgot that the tires will pickup allsort of crap, specially if you're on the outerparts of the racing line
Can't wait for the new engine though, that will be a lot more fun
Posted: Mon May 09, 2016 12:36 am |
Edward wrote: |
Excellent. I'm surprised you still have the air conditioning pump still in there. Would be interesting to see how the EW12 likes to rev with it being a longer stroke than the EW10. |
Doesn't seem to rev any slower than the 138. Well not that I can notice, I done the conversion about 6 months ago. Still running 138 ecu atm hoping to fit a piggyback to properly control the vvt as its just on a switch atm.
| Black 206 Gti. Soon to be 2.2 | |
