Latest: lio94
Overall: 17181
Online Now [111]:
Visitors: 110
Today: 25402
Total: 141275768
Forums › The Car › Request a how-to › trailing arm bearings
Forum IndexRequest a how-to
Go to page 1, 2, 3  Next
ghosty1970
PostPosted: Thu Feb 02, 2012 2:27 pm Reply with quote Up
just tried replacing these trailing arm bearings but failed . got them in the trailing arm no probs 5 mins . but getting the arm back on was a diff matter , couldnt get it all the way in about an inch left i think it had something to do with the red bars that attach to both ends { are they anti roll bars ? } tried and tried but in the end the new bearings collapsed . is there a proper or easier way to do it , got to buy another bearing nkoe ,, bugger .
leighton
PostPosted: Thu Feb 02, 2012 4:11 pm Reply with quote Up
You should completely remove the red torsion bars when putting the arms back on the tube.
PostPosted: Thu Feb 02, 2012 4:16 pm Reply with quote Up
If its the anti roll bar, thats inside the axle tube. The red bars are more than likely the torsion bars. On all the bars you need to match up the spines in order to get the opposite side on. Did you take measurements before you took it all apart? Also the new bearings will need greasing. If the bearings have been shot for a while it will also more than likely scored the axle tubee.
Dont take this the wrong way, but do you know what your doing? Have you got a guide?
Rob2859
PostPosted: Thu Feb 02, 2012 4:38 pm Reply with quote Up
Forgot to mention this. If its bad then you might as well not bother replacing the arms.
ghosty1970
PostPosted: Fri Feb 03, 2012 5:48 am Reply with quote Up
yes i did take measurements before stripping & greased bearings , only 1 side of torion bar comes loose other side is solid . and no i havent got a guide ?? does the torsion bar come off both ends ??? if so i will try and knock it harder .
leighton
rick-gti
PostPosted: Fri Feb 03, 2012 5:52 am Reply with quote Up
have a look at this:
www.206info.co.uk/Foru...28351.html
Also i beleive you do one side at a time when doing it.
clio 197sport owner
ghosty1970
PostPosted: Fri Feb 03, 2012 8:11 am Reply with quote Up
so do i just knock as hard as i can to get the torsion bar off or can i refit without taking it off, although i failed first time . i have another axle as well but that seems stuck as well ???
i am not completely twp but past half way .
any help or suggestions will help but probably go in 1 year & out the other .. only kidding
leighton
ghosty1970
PostPosted: Fri Feb 03, 2012 2:17 pm Reply with quote Up
any advice would be greatly apreciated .
leighton
PostPosted: Fri Feb 03, 2012 2:22 pm Reply with quote Up
They only knock out one direction. Follow the guide, should be of help.
Rob2859
PostPosted: Fri Feb 03, 2012 6:28 pm Reply with quote Up
Brake fluid is good to free stuff up. Just be careful what you are doing.
Fifer
PostPosted: Sat Feb 04, 2012 10:51 am Reply with quote Up
Anti roll bar won't come into play untill the end plate gets refitted. Did you clean the torsion bar splines and hole and then grease.
Guides below
This sites how to
Very good you tube guides
m.youtube.com/index?de...8eP5KZdSFs
1.4hdi 02
Fifer
PostPosted: Sat Feb 04, 2012 10:53 am Reply with quote Up
Part 2
m.youtube.com/index?de...kMVaDVdVaI
1.4hdi 02
Fifer
PostPosted: Sat Feb 04, 2012 10:55 am Reply with quote Up
And finally three
m.youtube.com/index?de...IndgZR7mu4
When I did mine on thur, drivers rear, the torsion bar was jammed solid that side. In the end it cam out the passenger side so the torsion bar was still attached to the trail arm.
You will get the arm on so far, then it's a case of moving the arm up and down to engage the correct splice for the torsion bar. Once it's engaged after a few taps measure. If it too low or high reverse the direction to disengage and put it on another spline. If not you will lower or raise that side.
1.4hdi 02
ghosty1970
PostPosted: Sun Feb 05, 2012 6:43 am Reply with quote Up
torsion stuck solid on mine too , tried reinserting with it on but no joy and knackered my new bearings i put in . if i bugger the next lot up i wont be a happy bunny . wish i went to a garage now. ps. those links dont work for me . ??
leighton
ghosty1970
PostPosted: Sun Feb 05, 2012 7:04 am Reply with quote Up
which way should i be hitting the torsion bar [ driverside stuck } hitting from outside in / inside out ?/ passenger side was outside in . do you know what i mean ??
leighton
Page 1 of 3
  Quick Reply
Username:
Message:
Quote the last message
