Online Now [321]:
Visitors: 320
Today: 117078
Total: 128490478
Forums › The Car › Solved 206 Problems › Non Working speedo 206 HDI X/2000
Spiky
PostPosted: Fri Apr 13, 2012 12:53 pm Up
ok, tried a few things with it now, but not sure what to try
put a new VSS on today, still nothing
tried a different dash cluster, no change
tried the reversing with door open, nothing happens
any one what the pin outs are on the VSS
1
2
3
i guess 1 is 12v, 1 is earth and the other is the speed?
which is which?
thanks for any advice Smile
206 HDI Dturbo X/2000
Spiky
PostPosted: Sun Apr 15, 2012 7:51 am Up
anyone?
also, do any wires from the VSS go via the round plug infront of the passenger front wheel?
PostPosted: Sun Apr 15, 2012 7:52 am Up
What ECU?
EDC15c2...one plug or three?
Spiky
PostPosted: Sun Apr 15, 2012 8:03 am Up
1 plug
PostPosted: Sun Apr 15, 2012 9:37 am Up
pin 2 > earth = 0ohms
Ping 1 > earth = 11-14 volts
PostPosted: Sun Apr 15, 2012 11:05 am Up
Yes it does go via the plug behind the bumper. Check the connections are ok.
Spiky
PostPosted: Mon Apr 16, 2012 3:08 am Up
ok cheers,
the wheel arch protector is missing so that plug has been getting hit by the elements,
i may just remove it and solder all the connections together Smile
don't suppose you know what pin does what?
Spiky
PostPosted: Tue Apr 17, 2012 11:15 am Up
ok had the multimetre out
pin 1 goes via pin 34 on the big round plug in front of passenger wheel and is getting 12v
pin 2 is going to earth, and is ok
pin 3, i cant trace via the big round plug
does the pin go via the big round plug? or does it go direct to ECU?
if it goes via big round plug, then i have found my fault and just need to work out which pin Smile
Spiky
PostPosted: Wed Apr 17, 2013 1:37 pm Up
Working now, I run a new cable from ecu to rear if clocks
All fine now
