Latest: DanDan17
Overall: 17128
Online Now [135]:
Visitors: 134
Today: 17910
Total: 100416087
Forums › The Car › 206 Problems › What is it?
What is it?
Ash_guff
PostPosted: Mon Feb 06, 2012 8:28 am Up
Hi iv got a 1999 gti 137 iv noticed that inside the cam pulley closest to the bulk head there is a metal insert sat inside that can be removed could someone tell me what its for?
IF IT BREAKS,IT BREAKS,ITS FRENCH!
PostPosted: Mon Feb 06, 2012 9:28 am Up
Like a bolt? Are there 3 of them?
Ash_guff
PostPosted: Mon Feb 06, 2012 9:40 am Up
No its like a metal disc it sits perfectly inside the
Pulley but its not bolted or nothing u can just take it out lol i thought i may act as a weight or something i dont no =\
Big_Rich180
PostPosted: Mon Feb 06, 2012 9:41 am Up
Do you have a picture?
Ash_guff
PostPosted: Mon Feb 06, 2012 10:01 am Up
Not just yet in work at the min il post 1 asap tho
gixxerkev
PostPosted: Mon Feb 06, 2012 10:07 am Up
It could be a balance weight so it runs true, just like a wheel weight. Strange how its not fixed though.
An Ex '03 1.4 GLX driver, German technology all the way now.
PostPosted: Mon Feb 06, 2012 12:08 pm Up
its called a thrust washer its meant to be there Wink
Ash_guff
PostPosted: Mon Feb 06, 2012 12:53 pm Up
s1178.photobucket.com/...mage-4.jpg
Ash_guff
PostPosted: Mon Feb 06, 2012 12:55 pm Up
Ok cheers bud i best put it back in now then :L
