Latest: elelectricistadeMateo
Overall: 17127
Online Now [154]:
Visitors: 153
Today: 11423
Total: 100409625
Forums › The Car › 206 Problems › Noisy Car update
Noisy Car update
Ajo123
PostPosted: Tue Feb 07, 2012 12:03 pm Up
I posted about this small problem a while ago here:
www.206info.co.uk/Foru...41375.html
Since this post, the car was relatively quiet and doing as it was told. I still took it to the garage to get looked at but sods law it made no noise so they didnt know what i was on about. They fitted a new fan belt anyway for nothing so that was nice enough, but the next time i started it from cold the noise came back and now its worse than ever!
This is really annoying because it wasnt there when i bought it and its pretty embarrasing for the first 5 minutes of driving, before it all quietens down again when the engines warm.
Heres a short vid of the noise, its definately coming from the fan belt area. Is it something simple as just tightening or loosening a couple of screws?
www.youtube.com/watch?v=cKZA_afC45g
any help much appreciated.
206 Sport 1.4 16v
ukskater01
PostPosted: Tue Feb 07, 2012 1:41 pm Up
Put a bit of talcUm powder on the belt, should quiet it down
Razor34
PostPosted: Tue Feb 07, 2012 1:47 pm Up
When they changed the fan/aux belt did they change the tensioner spring. I had the same sort of problem and when they did both it solved the problem!!!
Belt is self tensioning so would not need to tighten anything
Ray
Ajo123
PostPosted: Tue Feb 07, 2012 3:05 pm Up
Thanks for the talc idea ill try that when i get a chance.
As far as i know they only changed the belt, is the tensioner something i coukd do myself with nearly no car expertise or should i just take it back?
206 Sport 1.4 16v
Razor34
PostPosted: Wed Feb 08, 2012 1:30 am Up
I would take it back. The talc will only solve the problem short term.
Ray
PostPosted: Wed Feb 08, 2012 2:54 am Up
Sounds like one of the pulleys is on its way out. Best bet is too remove the belt and check for any movement in the pulleys.
