Posted: Mon Feb 13, 2012 1:56 pm |
hi guys and girls i am going to adjust the handbrake on the cc tomorrow using this guide, it is multiplexed so if i am disconnecting the roof switches etc do i need to disconnect the battery thank you
Posted: Mon Feb 13, 2012 1:57 pm |
why do you need to disconnect the battery when doing the brakes?
Posted: Mon Feb 13, 2012 1:58 pm |
Sorry enlighten me what does a handbrake cable got to do with switches?
Posted: Mon Feb 13, 2012 2:01 pm |
because the bsi or what ever it is and when messing with electrics sometimes you should disconnect the battery and i have the roof switch in the panel that needs to be removed so have to disconnect it
Posted: Mon Feb 13, 2012 2:10 pm |
well i still don't quite get it but if you wish there is no harm to disconnect the battery.
but make sure you following the bsi shut down guide
Posted: Mon Feb 13, 2012 2:12 pm |
if its not needed i wont bother
Posted: Mon Feb 13, 2012 2:16 pm |
It is good practice....
Just leave the ignition switched OFF while the switch is unplugged.
Posted: Mon Feb 13, 2012 2:17 pm |
ok mate cheers
Posted: Mon Feb 13, 2012 4:08 pm |
how do you remove the window switches is it just unclipped the same way as the bck cover e.g. with a screw driver
