Posted: Thu Feb 09, 2012 1:42 pm |
I posted about this last year and didn't get anywhere. Thought I'd give it a go again.
The engine resists to accelerate at about 1500 - 2000 rpm. It also kicks out a lot of black smoke from the tail pipe at the same time. I've given it a service changing all filters and the oil. I've also tried some injector cleaner but doesn't seem to have done the trick. Any ideas anyone?
Posted: Thu Feb 09, 2012 2:40 pm |
what is the status of your EGR?
Posted: Thu Feb 09, 2012 4:16 pm |
i vote for death turbo
Posted: Thu Feb 09, 2012 4:49 pm |
Its not overfull with oil is it?
Posted: Tue Feb 14, 2012 12:29 pm |
I haven't messed with my EGR, and my oil level is nicely between min and max reading on the dip stick.
Posted: Tue Feb 14, 2012 12:37 pm |
have you tried ragging it a bit to clear it out?
Posted: Tue Feb 14, 2012 12:43 pm |
Yes, also tried long motorway runs.
Posted: Tue Feb 14, 2012 12:44 pm |
Its probably what seabook said then. does it pick up a bit when you get to about 2500rpm?
Posted: Tue Feb 14, 2012 12:53 pm |
Yeah, it is mainly at 1750 rpm.
Posted: Tue Feb 14, 2012 1:20 pm |
It doesnt really sound like anythings wrong then really, its not going to be as responsive at low revs as the turbo hasnt kicked in.
Posted: Tue Feb 14, 2012 1:21 pm |
| Seabook wrote: |
| i vote for death turbo |
I'd be siding towards this too
| Abzynthe wrote: |
| It doesnt really sound like anythings wrong then really, its not going to be as responsive at low revs as the turbo hasnt kicked in. |
Turbo kicks in at 1850 + or - 50rpm
Posted: Tue Feb 14, 2012 1:29 pm |
| Abzynthe wrote: |
you got a 2.0HDI sw so i can't believed you say this
stock engine got peak torque at 2000rpm at 1 bar boost.
any rev. between 1500 to 2500 should have plenty of poke.
anthing after that will just die out
Posted: Tue Feb 14, 2012 1:33 pm |
| Seabook wrote: |
| Abzynthe wrote: |
anthing after that will just die out |
I dont know what Im talking about I know my car works
