Latest: heikkisj
Overall: 17126
Online Now [420]:
Visitors: 419
Today: 31042
Total: 100363998
Forums › The Car › 206 Problems › Rear Beam
Rear Beam
nellyhaggis
PostPosted: Sun Feb 12, 2012 3:26 am Up
Has anyone fitted a GTI 180 rear beam to a normal 206?
Is it a straight swop?
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Sun Feb 12, 2012 3:38 am Up
Depending on the age of your car the ABS sensors could be different and the lateral links will hit your exhaust.
nellyhaggis
PostPosted: Sun Feb 12, 2012 4:23 am Up
its a 206 gti hdi.
I wanted the 180 beam as it has the supports/tie rods.
PostPosted: Sun Feb 12, 2012 4:30 am Up
well you won't have the mounting point to fit them and you will need custom exhuast and remove the spare tyre+cage
