Latest: heikkisj
Overall: 17126
Online Now [302]:
Visitors: 301
Today: 30085
Total: 100363041
Forums › The Car › 206 Problems › Body Panels
Body Panels
GTSX
PostPosted: Sun Feb 12, 2012 2:55 am Up
Due to some ice on the road I need some body panels. I've found most of what I want on e-bay but I can't find a sill panel. The drivers side got a dent in it from a rock, just the first 6 inches.
Where can I get a drivers side sill panel
PostPosted: Sun Feb 12, 2012 3:46 am Up
Peugeot main dealer, there WELDED on so it needs a PROFESSIONAL to replace it!
PostPosted: Sun Feb 12, 2012 3:48 am Up
Peugeot dealer, or you'll need to cut it off another car which will be difficult. £320.
PostPosted: Sun Feb 12, 2012 4:19 am Up
there is a reason why you can't find those parts on ebay
