Latest: Kifi69
Overall: 17183
Online Now [485]:
Visitors: 484
Today: 37319
Total: 144328922
Forums › The Car › 206 Problems › HELP! 180 gearbox oil
fmonkey
PostPosted: Mon Feb 13, 2012 8:17 am Up
Where do I put my gearbox oil?
How much goes in I f****d up and dropped it..
Any help would be great pictures I can't find anywhere to put it back in?
Just on here to help with problems with car
Big_Rich180
PostPosted: Mon Feb 13, 2012 8:23 am Up
There should be a little metal plug in the top of the box and i think it takes 3ltrs.....this could be wrong though.
PostPosted: Mon Feb 13, 2012 8:26 am Up
If you take the battery out, there's a breather hole on top of the gearbox, black plastic, that's the easiest. The proper fill point is on the side of the box, but it's a pain to fill up from there. I think it's 2 litres of oil, but you'll have to check. It's the same as the 138 engine, and the 2.0 hdi.
PostPosted: Mon Feb 13, 2012 8:53 am Up
1.9 litres of Total 75w80 transmission oil.
How to change/top up gearbox oil here: 206gti.net/gear-oil/
PostPosted: Mon Feb 13, 2012 9:15 am Up
Just under £8 for a 2 litre bottle from any Peugeot / Citroen main dealer Whistle...
fmonkey
PostPosted: Mon Feb 13, 2012 9:50 am Up
Legends all done I took the battery off it was a lot easier that why so thanks everyone just under 2 litres it took
Cheers again
PostPosted: Mon Feb 13, 2012 9:52 am Up
Cheers again
Its ok to do it through the breather if you know it's empty, otherwise you run the risk of over-filling it.
fmonkey
PostPosted: Mon Feb 13, 2012 10:10 am Up
Yeah I emptied the thing so it's was empty, cheers mate
PostPosted: Mon Feb 13, 2012 11:34 am Up
So we all know about the bodgers method, the correct method is even easier - just use the filler plug on the side!
sri16v
PostPosted: Mon Feb 13, 2012 1:39 pm Up
agree with this man, also you can put the correct amount of oil in without overfilling
2004 GTi 180
juzza
PostPosted: Mon Feb 13, 2012 2:36 pm Up
is that not the drain plug?????
just asked a similar question on here because my ma5 box doesnt have a filler bolt
206 1.4 16v quiksilver
PostPosted: Mon Feb 13, 2012 2:39 pm Up
No, its the FILL / LEVEL hole Wink
Drain is on the bottom.
Using a oil can is a good idea when re-filling, then you can easily measure how much you have put in.
juzza
PostPosted: Mon Feb 13, 2012 3:28 pm Up
yeah sorry my bad,this is a B gearbox and mine is a m...
gpvecchi
PostPosted: Mon Feb 13, 2012 3:44 pm Up
I work in Citroen... In our garage we prefer to use 75W90, it resists better to high temperature, it solved many problems... Personally I add X1R friction eliminator to gearbox oil, it works wery good (it's totally unuseful in engine oil, insthead)...
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
