Posted: Tue Feb 07, 2012 3:58 pm |
I have just purchased this below
I have fitted aftermarket wheels before but without linking the horn up. So has anyone fitted one that could advise me on how to fit it properly with the horn working etc.. ?
Also is there certain boss's that I should stay away from like, without self the cancel bit or something like that?
Posted: Tue Feb 07, 2012 4:07 pm |
Fitting / having that steering wheel will be an MOT failure on a 206 from April.
Pointless mod on a road car.
Just sell it on & let some chav find out the hard way
Posted: Sat Feb 11, 2012 2:54 pm |
why will it be mot fail new rules etc
and its easy to do just connect the wires to the new horn cant go wrong really
Posted: Sat Feb 11, 2012 3:23 pm |
| usher wrote: |
Correct.
All UK spec 206 had a drivers airbag factory fitted so removing it will be an automatic mot fail
Posted: Mon Feb 13, 2012 8:58 am |
I am not permanently keeping the steering wheel on and would like to take it to a track once or twice a year so I could easily swap the wheel over as it take about 5 minutes to swap over.
I have used a 2amp fuse that has been soldered to two wires and connected the air bag connector and completes the circuit so the warning light works as it should, my only problem is how to wire the horn up correctly and I have no access to a multimeter until I return to work on Wednesday and to be honest I'm not all to clued up on the electrical Side of things.
My problem is that in the picture below you will see the original connector and two wires with spade connectors that I will be connecting back in. The horn however only has one spade connection on it so am I missing something?
Posted: Mon Feb 13, 2012 9:23 am |
The horn is probably earthed through the bolt that holds it to the chassis.
I can see a dead 206 coming up very shortly.
Posted: Mon Feb 13, 2012 9:34 am |
| macca1411 wrote: |
I can see a dead 206 coming up very shortly. |
Why do you even need a horn on a track car?
Posted: Mon Feb 13, 2012 9:38 am |
| MrBSI wrote: |
| macca1411 wrote: |
Why do you even need a horn on a track car?  |
To beep at the girls as you drive past like a hero
Posted: Mon Feb 13, 2012 9:41 am |
| macca1411 wrote: |
We shall see. A couple of hot laps can't do it too much harm....... **Touches a big piece of timber**.
So one of them wires will be live and one will be for earth. So I should find out which is which and connect the live to the horn and ground the other one. As you can tell electronics are not my strong point.
Posted: Mon Feb 13, 2012 9:42 am |
| Big_Rich180 wrote: |
| MrBSI wrote: |
| macca1411 wrote: |
To beep at the girls as you drive past like a hero  |
Took the words out of my mouth
Posted: Mon Feb 13, 2012 10:18 am |
| Ahoward87 wrote: |
| macca1411 wrote: |
As you can tell electronics are not my strong point.  |
I refer to my previous comment.
If you are not 100% sure about what you are doing, leave well alone.
Posted: Mon Feb 13, 2012 10:19 am |
| Ahoward87 wrote: |
| macca1411 wrote: |
We shall see. A couple of hot laps can't do it too much harm....... **Touches a big piece of timber**. |
I don't think he means your driving.
Posted: Mon Feb 13, 2012 10:44 am |
| tomd0801754 wrote: |
| Ahoward87 wrote: |
| macca1411 wrote: |
I don't think he means your driving.  |
I LOVE the smell of a fried BSI unit in the morning
Posted: Mon Feb 13, 2012 10:55 am |
Watch me prove you wrong!,. I'm normally making things work again and getting it tip top then break my cars thank you!,!
If this car is dead in 1 year I will give Macca a crisp £20 note for being mystic meg.
Posted: Mon Feb 13, 2012 3:24 pm |
Red is live and green is negtive i got steering wheel same put red on bk of the horn then put green through one off the bolt holes in ya boss then bang the wheel on
| peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim | |
