Latest: jackrox1992
Overall: 17186
Online Now [891]:
Visitors: 890
Today: 6775
Total: 147975733
Forums › The Car › 206 Problems › ABS question
ABS question
ej2_sir
PostPosted: Mon Feb 13, 2012 4:05 pm Up
Ive got a 2002 multiplex car with rear drums and abs (knackered axle). I have just bought a 2000 plate rear disc beam with ABS to replace it with. Im guessing the plugs will be different due to multiplex/non plex. Is it just a case of re wiring the plugs or is anything else required?
2002 206 2.0hdi
PostPosted: Mon Feb 13, 2012 4:33 pm Up
I don't think it's that simple. Pretty sure the wires have different functions and you need a multiplexed one.
ej2_sir
PostPosted: Mon Feb 13, 2012 4:47 pm Up
bugger! Would I be able to use my abs sensors/wiring with the pre plex beam? or are drum/disc sensors different?
2002 206 2.0hdi
ej2_sir
PostPosted: Wed Feb 15, 2012 5:20 pm Up
Another q, have received disc beam and it is the older tooth type rather than the magnetic type my drum abs has. So I'm wondering are disc and drum trailing arms the same? Can I fit my hubs complete onto these trailing arms? Thanks in advance
2002 206 2.0hdi
PostPosted: Wed Feb 15, 2012 6:01 pm Up
the stud pin are different in length (drum is shorter)
ej2_sir
PostPosted: Thu Feb 16, 2012 1:54 am Up
Ok thanks so can I use the stub pins out of my drum trailing arms? Thanks
2002 206 2.0hdi
