Online Now [1001]:
Visitors: 1000
Today: 118620
Total: 151901199
Forums › The Car › Request a how-to › How to fit gti 180 front seats
PostPosted: Wed Feb 15, 2012 6:18 pm Reply with quote Up
How easy is it to fit 180 front seats and how do i go about it?
Lewis
PostPosted: Wed Feb 15, 2012 6:20 pm Reply with quote Up
surely they just bolt onto your rails and plug the airbag in?
Tivoli LX 1.1
Black GTI 180
White VXR Burg
iainlovatt
PostPosted: Wed Feb 15, 2012 6:25 pm Reply with quote Up
Really 4 bolts and its done, plug the airbas in should u want to use them!!
(My Garage)
PostPosted: Wed Feb 15, 2012 6:30 pm Reply with quote Up
I assume the you mean the 4 bolts which secure the subframe into place?
L5_UKS
PostPosted: Wed Feb 15, 2012 6:39 pm Reply with quote Up
Yep
jimjam19927
PostPosted: Thu Feb 16, 2012 3:22 am Reply with quote Up
Off the top of my head its a T40 head you need. Smile Its rather simple. Just slide the seats forward and backwards to enable you to access the bolts. The seats come out attached to the runners. Straight swap nice and easy.
Craig and I swapped our interiors over for eachothers over the weekend. We had both done one set each before but it only took an hour and a half to do all 4 door cards, front seats, back seats and glove box lid.
I recommend having a can of wd40 or something similar to hand if you havent done your car before as I found some of my rear seat bolts were a little stiff!
Member: 685
I Over Use Smilies Razz
  Quick Reply
Username:
Message:
Quote the last message
