Online Now [1155]:
Visitors: 1154
Today: 99822
Total: 151233273
Forums › The Car › Solved 206 Problems › Slight smell in the interior [Update]
Forum Index › Solved 206 Problems
Daeva
PostPosted: Wed Feb 15, 2012 11:44 am Up
We' ve checked for water, we've used spray for the air con twice, it does not seem to come from the vent.
Also checked for any obvious causes (left food e.t.c).
Any ideas what it might be, or where else to look for water apart for seats e.t.c.?
Solution: Remove cat food crumbs from cabin.
1.4i, 2007, TU3A, 5-door, Moonstone
Ash
PostPosted: Wed Feb 15, 2012 11:49 am Up
Is the interior dry?
Daeva
PostPosted: Wed Feb 15, 2012 11:52 am Up
We check everywhere for water but nothing.
Ash
PostPosted: Wed Feb 15, 2012 11:56 am Up
Yeah but it could be moisture and stuff. I'd dry the car with a heater first.
Do it safely.
PostPosted: Wed Feb 15, 2012 12:01 pm Up
Checked under the boot mat?
Daeva
PostPosted: Wed Feb 15, 2012 12:09 pm Up
yes. No water accumilated.
Could the mat be just slightly damp and causing it?
PostPosted: Wed Feb 15, 2012 12:25 pm Up
Do you run your air-con regular?
PostPosted: Wed Feb 15, 2012 12:30 pm Up
Love juice?
Daeva
PostPosted: Wed Feb 15, 2012 12:32 pm Up
No, I run it once every couple of months during winter for five minutes each time, so it doesn't break down.
But it's not coming from the vents.
PostPosted: Wed Feb 15, 2012 1:05 pm Up
Lee wrote:
Love juice?
I hope not..
Cut it out Lee, this is serious.
PostPosted: Wed Feb 15, 2012 1:07 pm Up
Check for damp under the mats, and in the insulation in the boot and in the rear quarters
Check the condition of the pollen filter and a/c gas
Check the CAT....blocked/damaged CAT smells ergh
Daeva
PostPosted: Wed Feb 15, 2012 1:31 pm Up
OK.
Well check.
Thankyou.
Daeva
PostPosted: Fri Feb 17, 2012 3:40 pm Up
Checked everything and found two straw mats from the summer in the boot.
After I had them removed and thrown away, the smell vanished.
Thank you for the help.
Hopefully this one is solved
Smile
PostPosted: Thu Feb 23, 2012 3:23 am Up
I have now apologised and removed the GPS tracker from the vehicle.
Daeva
PostPosted: Fri May 03, 2013 6:20 pm Up
Update: it wasn't the straw mats, it was discovered that remnants of cat food (dry feed) from doing the rounds in various places, had dropped in the rear foot wells, which caused the smell again.
Problem now solved.
