Posted: Thu Feb 16, 2012 1:20 pm |
hi everyone
im not sure if this is a problem or just a normal thing ( never noticed it in other cars )
i have a 206 1.4 sport and have noticed a strange ticking noise every 30 or so seconds coming from the engine bay ( can be heard inside the car too with bonnet closed ) any info as to what it is would be very much appreciated
if im being dumb please dont laugh too hard at me
Posted: Thu Feb 16, 2012 1:28 pm |
You sure its not your rear wiper relay? ;),
My sister was shouting at me saying I was chewing some gum too loud but it was the relay... LOL
Poppy, My 2.0 HDI Dream  | |
Posted: Thu Feb 16, 2012 1:33 pm |
its happening without rear wiper on ( its much louder than that ) i thought it might be just things warming up but after a 3 hour journey i still had the noise. ( if you chew gum that loud i wouldnt want you in my car either lol )
Posted: Thu Feb 16, 2012 1:55 pm |
Poor Engine lubrication, loose valve or leaking exhaust manifold.... so i just read on google ( if in doubt, google it ) as my oil levels are fine im guessing its one of the latter
Posted: Thu Feb 16, 2012 2:28 pm |
if anyone else has any suggestions as to the cause before i go to a garage, they are appreciated too.
Posted: Thu Feb 16, 2012 2:31 pm |
Sorry i dont know the answer, but im sure people will try help! Be patient
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
Posted: Thu Feb 16, 2012 2:48 pm |
im sure they will lewis as i cant be the first or the last
Posted: Thu Feb 16, 2012 5:43 pm |
Do you have your AC on per chance?
Posted: Fri Feb 17, 2012 1:51 am |
to be honest, i couldnt tell you if it was on or not at the time of the noise. i dont hear it all the time which would probably explain it, as normally i knock the AC off when driving but have forgot at times. will have to look into that. thanks pal
Posted: Fri Feb 17, 2012 5:35 am |
my cambelt has started "tapping" on the inside of its casing, have a little squeeze on the casing and see if the noise changes/gets worse goes away etc
Posted: Fri Feb 17, 2012 12:37 pm |
thanks lottley, i will also look into this
Posted: Fri Feb 17, 2012 1:31 pm |
Most likely the brown electrovalve for the emmisions system.
