Latest: elelectricistadeMateo
Overall: 17127
Online Now [55]:
Visitors: 54
Today: 25568
Total: 100398241
Forums › The Car › 206 Problems › 2005 206 hdi gti, front wheel knocking
vauxfan
PostPosted: Fri Feb 17, 2012 10:49 am Up
The car has started light knocking from the front wheel. so today i grabbed it and pulled it left to right, there was movement in the wheel and there was some movement when doing the same at 12 and 6 oclock. wheel studs are tight and the knock i don't think is the arm or steering rod. so do you think the bearing has gone? there is no rumbling. what size is the hub nut and have you done one?
pug all the way
PostPosted: Fri Feb 17, 2012 11:06 am Up
You will need a press if you want to change the bearing.
vauxfan
PostPosted: Fri Feb 17, 2012 11:21 am Up
thats not a problem, can use the work 1. what size is the nut?
pug all the way
Lewis
PostPosted: Fri Feb 17, 2012 11:26 am Up
Sounds like drop link or top mount, can't remember which one lol. Sorry.
Tivoli LX 1.1
Black GTI 180
White VXR Burg
PostPosted: Fri Feb 17, 2012 12:05 pm Up
i think is 34mm, if not try 32/36
vauxfan
PostPosted: Fri Feb 17, 2012 12:59 pm Up
pld 206 was a 32, but this is a 34 i think, did a little more investigation and it appears to be the inner track rod. bought a new 1 to pick up tomorrow, lemforder. buying the best 1s as they will out last the car that way.
pug all the way
PostPosted: Fri Feb 17, 2012 1:02 pm Up
Thats wont be to difficult Rolling On The Floor Laughing
vauxfan
PostPosted: Fri Feb 17, 2012 1:08 pm Up
MrBSI wrote:
Thats wont to difficult Rolling On The Floor Laughing
i knew that would be a reply from you! even with out seeing the name.
pug all the way
