Online Now [596]:
Visitors: 595
Today: 68173
Total: 152474558
Forums › The Car › 206 Problems › Brake disc locator bolts
fmonkey
PostPosted: Fri Feb 17, 2012 12:02 pm Up
Well changed disc and pads, on one side then the other side I could not for the life of me move the bolt so not it rounded.
Any help please?
Cheers
Just on here to help with problems with car
PostPosted: Fri Feb 17, 2012 12:04 pm Up
Tip with these is:
Impact driver with a correctly fitting bit in the end for the screw head
OR
Fit the bit in the disc screw then sharply smack it a couple of times with a hammer before you then attempt to undo it.
fmonkey
PostPosted: Fri Feb 17, 2012 12:08 pm Up
Now you tell me lol well I may have to go to a garage just to get one bolt off, how gay.
Can't I drill it out?
PostPosted: Fri Feb 17, 2012 12:11 pm Up
Get the drill out!
PostPosted: Fri Feb 17, 2012 12:49 pm Up
impact driver always work for me
PostPosted: Fri Feb 17, 2012 1:07 pm Up
You sure can drill it out,take the bolt head off,and you can then take the discs out,and it will be easier to hold the bolt now,and take it off,and buy new ones Very Happy
fmonkey
PostPosted: Fri Feb 17, 2012 2:32 pm Up
Cheers guys what a pain in the a**e. Bought myself some new ones 79p for two which is ok.
PostPosted: Fri Feb 17, 2012 2:51 pm Up
my new disc come with bolts......
PostPosted: Fri Feb 17, 2012 2:53 pm Up
What He Said
My Brembo's did to.
ianm92
PostPosted: Fri Feb 17, 2012 6:29 pm Up
you can also cut a line or hammer a line thru it so that you can use an impacted driver with a flat screw driver end to get them off be for u get the drill out Smile
MILLSY
