Latest: dreyfalon
Overall: 17121
Online Now [304]:
Visitors: 303
Today: 14358
Total: 97694937
Forums › The Car › 206 Problems › speed sensor connections
davecuk
PostPosted: Sat Feb 18, 2012 6:09 am Up
Hi, I'm sorting out my non working speedo has anyone got the wiring connection data for the plug on the sensor? Many thanks Dave 2001 non plexed 1.9 d
206 1.9 d silver
kit325
PostPosted: Sat Feb 18, 2012 6:49 am Up
What are the symptoms?
Did the speedo needle flick when u turn on or off the engine? It is common for non plexed 206 speedo cluster failed.
kit
davecuk
PostPosted: Sat Feb 18, 2012 7:03 am Up
hi, yes it does, i have replaced the sensor and tried a few other clock sets but i want to check the wiring in case there's a break somewhere so would like to know pin connection function to aid me
206 1.9 d silver
PostPosted: Sat Feb 18, 2012 11:48 am Up
Check the large connector behind the passenger side front bumper.
davecuk
PostPosted: Fri Mar 23, 2012 10:34 am Up
hi, still having probs with the speedo, has anyone got the connection details for the 3 pin plug on the gearbox sensor?thanks Dave
206 1.9 d silver
PostPosted: Fri Mar 23, 2012 11:33 am Up
Have you checked the connector behind the bumper? Wiring tends to be faulty at the terminals rather than along its length.
davecuk
PostPosted: Fri Mar 23, 2012 11:50 am Up
hi, thanks for that, I have got 12volts at the sensor but would like to know the pin out of the sensor plug. the loom has been replaced from the plug to a joint away from it, and I need to check the pin out so that it's correct so as to make sure that the speedo itself is ok.
206 1.9 d silver
Linkpad
PostPosted: Fri Mar 23, 2012 3:33 pm Up
I have the same problem with my 206 non plexed, i open the door and no alarm or lights go off when im driving so is this a wiring problem ?
Could anyone take a pic of where this passenger bumper connection is, do you mean under the wheel arch ? I looked everywhere for connections.
Boo
davecuk
PostPosted: Fri Mar 23, 2012 3:45 pm Up
hi, the connector is in front of the wheel arch liner, passengers side, it's a twist to release and a bind to get back in place, as there's a locking ring that takes some aligning to get back together.hope this helps, Dave
206 1.9 d silver
