Latest: heikkisj
Overall: 17126
Online Now [35]:
Visitors: 34
Today: 15029
Total: 100212638
Forums › The Car › 206 Problems › angel light
angel light
anton1989
PostPosted: Tue Feb 21, 2012 7:29 am Up
Trade Rating: +16
hello, hope someone can help, i have bought and fitted some angel lights to 206 everything works fine, but the sidelight holder dont go in???? i have tried to bodge them in (bad idea) but they fell out and melted to the plastic Sad
please help
thanks anton
Steve180
PostPosted: Tue Feb 21, 2012 7:33 am Up
Are they the normal Angel eye headlights, not projector or halo ring?
Is the sidelight holder the slim line one or the stubby one?
2004 206 GTi 180: 207.9BHP, 183.1 ft/lbs
anton1989
PostPosted: Tue Feb 21, 2012 7:40 am Up
Trade Rating: +16
hi, the have the have two halo rings on each.
dont know what you mean about the sidelight holder its just the original one that come on the 2001 models.
anton1989
PostPosted: Tue Feb 21, 2012 7:43 am Up
Trade Rating: +16
*they
Steve180
PostPosted: Tue Feb 21, 2012 7:44 am Up
Ok, slim line sidelight holder then.
It could be that the mounts for the holders haven't been made particularly well and hence the sidelight bulbs don't fit. But if you have Halo rings on the lights, these should replace the sidelight bulbs anyway?????
Halo rings are meant to be wired into the sidelight circuit so these come on before the dipped or main hence doing away completely with the sidelight?
anton1989
PostPosted: Tue Feb 21, 2012 7:53 am Up
Trade Rating: +16
so i dont need sidelights in? what about when it comes to a m o t?
i have also been told they will fail an m o t because they are not at the right aim??? is this true???
Steve180
PostPosted: Tue Feb 21, 2012 8:25 am Up
If they definitely have Halo rings fitted then no, they count as sidelights. I had angel eye halo ring headlights in my 306 and 106 and never had a problem with M.O.T.
To change the beam pattern, there should be adjuster screws mounted on the dipped beam housing which can be turned to change the pattern.
You will need to take the car to an M.O.T bay so they can adjust the headlights. It might also be worth talking to who sold you the headlights to confirm how to adjust the pattern.
anton1989
PostPosted: Tue Feb 21, 2012 9:25 am Up
Trade Rating: +16
was thinking the same, im going to just go to a m o t place and ask hem to sort it.
thanks alot.
