Posted: Wed Feb 22, 2012 10:19 am |
i'm pretty sure the fuse that controls the horn (little 10amp red) also does the right side full beam... my full beam works... but the horn dosent?
Any ideas? its past its mot due date and it know it will fail
Posted: Wed Feb 22, 2012 10:22 am |
No the horn does not share a fuse with the headlights.
Refer to the appropriate fuse list and take it from there.
Have you checked the fuse?
Its more likely to be the loom which attaches to the horn as Peugeot did a recall on 206's because of the wiring. If not, test meter across the horn and see if the horn beeps.
| 2004 206 GTi 180: 207.9BHP, 183.1 ft/lbs | |
Posted: Wed Feb 22, 2012 10:27 am |
| Steve180 wrote: |
Its more likely to be the loom which attaches to the horn as Peugeot did a recall on 206's because of the wiring |
They even sell a loom repair section for it
Normally the wires break at the plug due to corrosion, fixed a few before in my time.
Posted: Wed Feb 22, 2012 10:28 am |
We do indeed
Posted: Wed Feb 22, 2012 10:31 am |
Luckly I have plenty of suitable recycled spare plugs at work.
I normally charge a breakfast for repairing these
Fire up the soldering iron
Posted: Wed Feb 22, 2012 10:48 am |
ive checked the fuse is not broken.
Posted: Wed Feb 22, 2012 10:52 am |
Tried the wiring or even the actual unit?
Posted: Wed Feb 22, 2012 10:57 am |
well i dont know what to actually do to the loom? give it a tug or what? lol and then if i jack the car up to look at the horn.. then what am i meant to look for?
Posted: Wed Feb 22, 2012 12:56 pm |
Visit MR.BSI
