Posted: Thu Feb 23, 2012 12:21 am |
hey guys i have a PEUGEOT 206 QUICKSILVER 1.4 2004
the problem am having is that when i accelerate it is hesitating before then kicking in its like its not getting the fuel through that it needs, i have checked and changed spark plugs and changed the MAP sensor also changed air filter, also cleaned out the mass air flow sestem! there is no fuel filter so it cant be that and now am stuck for things to do.
can anyone hlep me?
Posted: Thu Feb 23, 2012 1:29 am |
Replace spark plugs, use Bosch brand.
Let the fuel run low and then refill to the brim with Shell v-power
Posted: Thu Feb 23, 2012 1:42 am |
| macca1411 wrote: |
Let the fuel run low and then refill to the brim with Shell v-power |
+1
Spot on advice.
And go for Bosch Super+, type no. FR7DC+ for 1.4i engine which is the recommended part.
Could also be throttle potentiometer.
Posted: Thu Feb 23, 2012 3:44 am |
thanx's guys and what's the throttle potentiometer?
Posted: Thu Feb 23, 2012 5:16 am |
Trade Rating: +32
Coil pack?
Posted: Thu Feb 23, 2012 7:24 am |
my car had the same problem started happening about a month ago, changed the sparks no luck, changed all 4 injectors and coil pack and its been working like a dream since hope this helps
| 1.4 8v, Slowly Getting There | |
