Posted: Fri Feb 24, 2012 5:32 am |
ok I'm about to drop another 180 engine in my car and wondering if I should change the clutch before I do so? Also anything else I should change before hand? Obviously I'll change the timing belt and waterpump.
Cheers
Posted: Fri Feb 24, 2012 5:49 am |
Are you using the gearbox from the engine your transplanting or from your own car? If its from your own car, I would change the clutch, input shaft bearing and check the condition of the clutch fork.
GTi 180's are known for clutch judder.
| 2004 206 GTi 180: 207.9BHP, 183.1 ft/lbs | |
Posted: Fri Feb 24, 2012 6:14 am |
Yeah gearbox from my own car. I'm getting a garage to do it for me so should I ask them to check the condition of these things before buying them? Also do you know if these items are expensive?
Cheers
| 2005 Peugeot 206 Gti 180, Silver, 38,000mls | |
Posted: Fri Feb 24, 2012 6:58 am |
The guide bush is £20.00 ish from Peugeot, clutch fork will be aound £30.00.
Posted: Fri Feb 24, 2012 7:12 am |
Right no worries. Cheers for all the advice. Car has been off the road for 6 months so will be a joy having it back.
Posted: Fri Feb 24, 2012 9:42 am |
Good stuff, glad to hear another 180 will be back on the raod
Posted: Fri Feb 24, 2012 12:33 pm |
change it while its easy peasy,
