Latest: heikkisj
Overall: 17126
Online Now [48]:
Visitors: 47
Today: 12511
Total: 100321895
Forums › The Car › 206 Problems › 206 Rear Caliper Problem
nellyhaggis
PostPosted: Mon Feb 27, 2012 5:04 am Up
Hi All,
Ive got a 206 Gti HDI 1.6 with rear calipers that I assume are sticking on.
Its worse when Ive been parked up over night and they get better when driving.
And the handbrake is poor at best when I park up.
Anyone else had this problem?
Any advice would be great.
Cheers in advance
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Mon Feb 27, 2012 6:24 am Up
Just strip them down, clean the pads where they touch the caliper, wind the pistons back in and see if all is well. Check the handbrake cable is free too.
