Latest: sparrowdclxvi
Overall: 17139
Online Now [165]:
Visitors: 164
Today: 22350
Total: 113222400
Forums › The Car › 206 Talk › RPO Number - Servicebox
PostPosted: Sun Feb 26, 2012 1:40 pm Up
Can Servicebox tell me my RPO number? What does RPO number mean?
PostPosted: Sun Feb 26, 2012 1:51 pm Up
Yep. If you enter the VIN and then go to 'Characteristics' heading on the left-hand coloumn, it brings up a list with loads of info on the car including the RPO right at the top.
RPO or DAM is like the 'build-code' and is used to refer to the manufacture process for exact parts used etc.
You can also find it on the sticker on the door pillar (if you still have it).
