Forums › The Car › 206 Problems › Suspension arm help |
Posted: Tue Feb 28, 2012 10:43 am |
hi guys, I'm looking at getting some of the advisory's from my MOT sorted, the one I'm most concerned about is "Offside front suspension arm has slight play in a ball joint"
would the part I'd need to replace be this??
www.ebay.co.uk/itm/Peu...138wt_1144
And if so how much should I be looking at to get it fixed??
I have another advisory from the same time but a different test centre stating " Offside front (rear) suspension arm has slight play in a pin/bush" any ideas what this means?
Also does anyone know the going rate for an oil and filter change?
I'm driving a 1998 Pug 1.1 206 lx
Thanks,
Any help is greatly appreciated
Posted: Tue Feb 28, 2012 11:44 am |
The pin bush is the rear axel, that arm is a good price get it why you can
Posted: Wed Feb 29, 2012 12:06 am |
its not a big job 1 hours labour tops for the front .
