Online Now [214]:
Visitors: 212
Bots: 2
Today: 58647
Total: 155776896
Forums › The Car › 206 Problems › Do I need brake compensator??
ej2_sir
PostPosted: Tue Feb 28, 2012 12:01 pm Up
My 2002 hdi beam (drum with abs) does not have a compensator/spring. The new beam I have sourced is a 2000? disc with abs and has a compensator/spring. Do I need to alter the brake lines to hook this up or do I pipe it like my old beam without?
2002 206 2.0hdi
PostPosted: Tue Feb 28, 2012 12:35 pm Up
Your 206 has ABS with EBD fitted so DO NOT fit a compensator valve on the rear axle!
ej2_sir
PostPosted: Tue Feb 28, 2012 12:51 pm Up
Lovely, one less thing to do! Where is the EBD located just out of interest, part of the abs module? As you can probably guess axles are an area im not good with but I am trying and youve been a big help! Cool
2002 206 2.0hdi
PostPosted: Tue Feb 28, 2012 12:52 pm Up
Correct.
