Hi I have recently got my 206. And the problem that I am having with it is on full lock either left or right it sounds like there is a knock or thud its really hard to explain it also feels like the tyre is jumping! I have had the both lower arms changed and it has had top suspension mounts changed in the past 7 months. Anyone got any suggestion's as to what could be causing this? I have also given the cv boots a visual inspection and there doesnt appear to be any grease leaking or splits in the gaitors. Noise aint apparent when driving in a straight line only when doing a 3 point turn.
Any help would be greatly appreciated.
2.0 SW HDi Quiksilver
-Dave-
Posted: Sat Mar 03, 2012 4:58 pm
Trade Rating: +36
Things that spring to mind on previous threads could be engine mount or maybe cheap top mounts which have failed.
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
