Posted: Sun Mar 04, 2012 8:04 am |
refrence :: i am about to up grade the look of my wee pug 206 v reg reading into all the jitter its not just a case of changing the lights it sounds like ive got to check other things to make do could someone clarify i thought 12 volt was same on all cars ?
Posted: Sun Mar 04, 2012 8:09 am |
What lights are you changing..
Posted: Sun Mar 04, 2012 8:41 am |
ALL to lexus type
Posted: Sun Mar 04, 2012 8:46 am |
Trade Rating: +36
Should be a straight swap. Have a look around though there are a lot better light's out there than lexus, Unless of course that's what you like.
Posted: Sun Mar 04, 2012 8:54 am |
I have not made a firm choice lexus just came to mind thank you anyway
Posted: Sun Mar 04, 2012 9:00 am |
Trade Rating: +36
Rear light's are a straight swap whereas front's may be different depending on if they are H4 or H7, You can get converter's though so it's not a major hassle.
Posted: Sun Mar 04, 2012 9:02 am |
I don't know why people slate Lexus lights, fair enough the chrome ones can look a bit tacky but you can spray them to match your car, I personally like the black Lexus lights as I had some on my first 206 and looked the dogs danglies
Posted: Sun Mar 04, 2012 9:09 am |
Trade Rating: +36
I think it's all about personal choice, I don't like the chrome one's at all but don't care what other people put on their car's. Some people get them as they are the cheaper option but nowadays most rear light's are cheap. But as you pointed out Raz CC one's do look good.
But the word Sheep spring's to mind when it come's to Lexus light's if you get what I mean
Posted: Sun Mar 04, 2012 9:36 am |
all intresting BUT always a but my little v reg pug where is the info to what is currently on h4 or whatever
Posted: Sun Mar 04, 2012 9:38 am |
Trade Rating: +36
V reg will be H4.
Posted: Sun Mar 04, 2012 9:46 am |
Suicidalsoldi3r wrote: |
But the word Sheep spring's to mind when it come's to LED light's if you get what I mean |
Edited for the truth
Posted: Sun Mar 04, 2012 9:51 am |
thank you lads all inputed to memory cheers
Posted: Sun Mar 04, 2012 12:55 pm |
Razpulsedj wrote: |
I don't know why people slate Lexus lights |
Because they where done to death on here 5+ years ago.
Posted: Sun Mar 04, 2012 1:56 pm |
MrBSI wrote: |
Razpulsedj wrote: |
Because they where done to death on here 5+ years ago. |
That was 5 years ago, now everyone has LED's therefore making them more followed than the Lexus trend IMO
Posted: Sun Mar 04, 2012 2:09 pm |
Razpulsedj wrote: |
but you can spray them to match your car |
Spraying lights is never a good idea. Like it or not any spray will reduce the light output which is not clever.
