Posted: Fri Mar 02, 2012 3:48 am |
Hi guys,
Cat is basically falling off but i know they are expensive.
Question is do i get it replaced or decat...
Ive been to loads of suppliers
Best Quote was £200 in cash. Not to sure if thats with the cat though.
But Best Quote With Cat Was £270 Not bad considering:
£350
£375
£400
From other stores.
Wondering how much should i be expecting when paying for for one including cat and not paying for a cat.
Plus is decating a 2.0 litre dturbo a problem, many of these have told me it ends up more expensive and that ill have all sort of problems as ecu will need changing ect.
Second question is:
Part one tyre 195 / 45 / R16 6mm tread... £30?
This good?
Cheers Guys thanks for reading.
Scott
| Breaking 2.0 hdi with ps and gti bits | |
Posted: Fri Mar 02, 2012 4:11 am |
Depends on brand of tyres chances are you can get a new one for that
And decats are illegal so dont get caught haha and make sure you have a cat for the mot (new mot rules are you must have a cat to pass)
| Image removed due to size
Team, ST
Team, Gti 138 track slag | |
Posted: Fri Mar 02, 2012 4:27 am |
Not on a diesel they ain't.
Scott - you won't need to change your ECU at all. Find your local powerflow dealer and get a whole system including decat for around £200.
Posted: Fri Mar 02, 2012 4:28 am |
M60SHW wrote: |
And decats are illegal so dont get caught haha and make sure you have a cat for the mot (new mot rules are you must have a cat to pass) |
Wrong on the de-cat they are not illegal on diesel and will pass the MOT with no problems.
The must have a cat to pass a MOT is only on petrols.
Posted: Fri Mar 02, 2012 5:25 am |
only if the car was produced after 1992
Posted: Fri Mar 02, 2012 6:31 am |
Have I not read that if a car had a cat when new it must have one fitted? Or is that just petrols?
Posted: Fri Mar 02, 2012 6:56 am |
Just petrols that applies to
Posted: Fri Mar 02, 2012 7:40 am |
Check with you local MOT station about the a legality. If legal get a powerflow cat bypass and exhaust system for the same money as a CAT only and sell you current pipe
| 206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box, | |
Posted: Fri Mar 02, 2012 8:03 am |
Trade Rating: +59
deebee wrote: |
Second question is:
This good? |
You get what you pay for
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Fri Mar 02, 2012 8:13 am |
Al think youl find in the new 2012 mot rules all cars that had one fitted as standard have to have one to pass mot well that's the brief iv been given.
www.theaa.com/motoring...-2012.html
Team, ST
Posted: Fri Mar 02, 2012 1:05 pm |
read the real doc.
diesel don't need cat.
Posted: Fri Mar 02, 2012 1:31 pm |
Seabook wrote: |
read the real doc.
diesel don't need cat. |
Posted: Mon Mar 05, 2012 7:28 am |
Right guys, I've phoned around garages and most say de-cat isn't the best when it comes to legal side. But sport cat is just as good, and I've been quoted £270 with sports cat and back box! just got to go and see it now, its john ashley exhausts great guy on the phone! check him out
Posted: Mon Mar 05, 2012 8:17 am |
There is nothing illegal about de-catting a diesel at all.
Did you tell them that you had a diesel or that you just had a Turbo?
Posted: Mon Mar 05, 2012 11:01 am |
Yep diesels are completely legal to de-cat, MOT passed everytime on my previous 2.0 hdi which had no cat.
