Recently started to hear a knocking at the rear of the car passengers side when turning right. Immediately thought it was suspension and after a quick search on here and "alternative" sources feared the worse of the axel starting to fail :s
Anyway took the proactive route and had it a garage today and they say there is slight play on the rear axle but nothing else is wrong or could be causing the knocking other than bushes but they dont replace them as its too big a job and quoted about £200-£250 at other garages.
Long story short my question is will it be ok driving around like this and is it a big job to do or something that i should find a "professional" to do?
Cheers in advance!!!
X REG 1.6 GLX
- PLATINUM SILVER -
Big_Rich180
Posted: Tue Mar 13, 2012 11:33 am
I wouldnt attempt the job your self if you are not competant in mechanics, try and find a french car specialist.
Infact i think there are a few people on here that will do the job, there's a guy from Doncatser on here that does them but i cant remeber his name.
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
