Latest: DanDan17
Overall: 17128
Online Now [398]:
Visitors: 397
Today: 34422
Total: 100554314
Forums › The Car › 206 Problems › Tyre/Steering
Tyre/Steering
Jeff48
PostPosted: Tue Mar 06, 2012 6:27 am Up
Hi,I had new Kumho 195-55-15 put on the front of my 2005 1.6 sport and all 4 wheels tracked. The problem is that the can seems to follow imperfections in the road,and at speed feels a bit "light/loose" is as best I can describe it!! Any Ideas?? Thanks.
JB&A106lincs
PostPosted: Tue Mar 06, 2012 9:31 am Up
First check would be tyre pressures.
Any car even with perfect suspension and steering will follow imperfections in the road surface. It's as if the tyre is sucked into it. Lane one on the motorway is usually the worst as the wagons create grooves in the surface.
DRAPER
PostPosted: Tue Mar 06, 2012 9:46 am Up
arent you only meant to put new tyres on the rear and then move the rear ones to the front when only buying two tires?
206 CC 2.0 GTI SE
HAPPY AS A PUG IN MUD
Lee wrote:
Buy a new car. The 1.9D is s**t anyway.
HA love it Smile
PostPosted: Tue Mar 06, 2012 1:21 pm Up
Never heard that one before. I don't mind as long as they have even tread wear on both sides of the axle.
I was wondering where my track rod end was on the rear though. If the receipt says "track all four wheels" I'd be asking for my money back, and taking the big flashing light off my head so they don't see me coming next time.
PostPosted: Tue Mar 06, 2012 1:29 pm Up
So you have never heard of 4 wheel alignment then?? This most likely what the OP is talking about.
As for tracking in the groves on the road, called tramlining. This can happen no matter what tyres you have so its nothing really to worry about just be more careful.
PostPosted: Tue Mar 06, 2012 1:32 pm Up
Just means you have to steer less, as it does it itself Laughing
Jeff48
PostPosted: Tue Mar 06, 2012 3:11 pm Up
It's bloody anoying though,it didn;t do it with the old tyres on?? Getting a guy to chech it over tomorrow.
JB&A106lincs
PostPosted: Tue Mar 06, 2012 3:13 pm Up
I most likely did but you didnt notice, now that you have new tyres you notice it more
Jeff48
PostPosted: Tue Mar 06, 2012 3:36 pm Up
Just hope i can cure it because i cant live with it as it is!!!
JB&A106lincs
PostPosted: Tue Mar 06, 2012 3:45 pm Up
Just learn to drive
Jeff48
PostPosted: Wed Mar 07, 2012 12:38 am Up
Ha Ha,decent car should perform correctly!
JB&A106lincs
gazza82
PostPosted: Wed Mar 07, 2012 3:12 am Up
Did you have TWO new front tyres or one ... one would certainly cause a problem as it has more grip than the other. It's also going to feel different. The pressures are right?
Yes, new tyres go on REAR ... even on a front wheel drive car ... it's better to understeer than oversteer (rear end loses grip)
New tyres also have to be run in ... the gunk they use in the factory to release them from the moulds doesn't all get washed off so they can be a bit slippy at first, especially in the wet.
AFAIK you can't have the rear of a 206 aligned. You can get it checked obviously, but they can't adjust anything. If it's out it's a mechanical issue (worn bushes or bearings, accident damage, etc).
Jeff48
PostPosted: Wed Mar 07, 2012 6:13 am Up
Yes I did fit 2 new front tyres.My garage checked it over,one front tyre had 42psi in it and the other 36psi,after a 10 mile drive home it did seem better...a little worrying though he said my rack end had been severely overheated (I remember the lad heating it up to do the tracking!) he also thinks the nuts have NOT been moved! So was the tracking even adjusted????The rackend could now be a possible MOT faliure! So do NOT use WILCO MOTORSAVE!!!!
JB&A106lincs
PostPosted: Wed Mar 07, 2012 6:18 am Up
get a new trackrod end then.
they do seized sometimes
perry081064
PostPosted: Thu Mar 08, 2012 5:06 am Up
i had exactly this problem myself so i understand where you are coming from. it was even worse on uneven country roads and quite scarey tbh.
what solved it for me was 2 new tyres , 2 wishbones , 2 droplinks and a retrack.
not saying you have to do it all , start with the tyres first and take it from there, i only had one knackered wishbone but had both done anyway.
as for the droplinks, they didnt really need doing , but was cheap enough so had them done at the same time.
you will deffo need tracking done after messing about in that area so make sure you finish with that.
hope this helps
206 2.0 HDI
