Posted: Mon Mar 05, 2012 8:50 am |
Daughters 53 plate 1.4 petrol 206, driving along when engine management light comes on with a bleeping sound
Not come across people mentioning the bleeping before ???
Parked for 5 minutes, start up again & running fine now!
| Growing old is mandatory, growing up is not! | |
Posted: Mon Mar 05, 2012 10:14 am |
Probably just the car having a hissy fit, if your worried go and get the codes read, or leave it and see if the problem happens again
Posted: Mon Mar 05, 2012 10:53 am |
Trade Rating: +36
Have you had the codes read?
Posted: Mon Mar 05, 2012 11:50 am |
Just had the same problem on the motorway on way home. Now gone so probably typical 206 electrical problems so dont worry about it unless you experience any loss of power!!!!
Posted: Mon Mar 05, 2012 11:57 am |
Definately read it ASAP.
Posted: Mon Mar 05, 2012 12:29 pm |
Is anyone local to the Croydon area who can check my codes for me just incase?
Posted: Mon Mar 05, 2012 1:10 pm |
Thanks, having the codes read tomorrow.
It did seem to run on 3 cylinders during the episode.
Posted: Wed Mar 07, 2012 12:45 pm |
Turns out it was the coil pack, all done today.
Now to fit the new front discs & pads.
Posted: Wed Mar 07, 2012 1:45 pm |
simbathedog wrote: |
Turns out it was the coil pack, all done today. |
Our felt like it had lost two cylinders when it went.
Now to fit the new front discs & pads. |
Piece of p*$$! Rears are a bit more fun. The small screws holding the disc to the hub might snap ... I bought some spares and one of those snapped off when replacing it. I'll drill that out one day ... Luckily the disc ain't going anywhere with a wheel bolted over it!
Posted: Wed Mar 07, 2012 1:50 pm |
You don't need them screwed that hold the disc to the hub anyway.
