Latest: heikkisj
Overall: 17126
Online Now [71]:
Visitors: 70
Today: 17046
Total: 100195676
Forums › The Car › 206 Talk › Trickle charge, need to disconnect battery?
fan168
PostPosted: Fri Mar 16, 2012 10:47 am Up
I have a Peugeot 206 Roland Garros 1.6 Auto. We have two cars so this one is only doing short journeys at the moment so planning to trickle charge the battery periodically to keep it topped up.
Do I need to disconnect the battery every time I charge it? I have one of those ctek chargers which can pulse charge. Read somewhere on the web that I wouldn't need to disconnect but just wanted to be sure.
gazza82
PostPosted: Fri Mar 16, 2012 11:15 am Up
Don't think you do with one of those. I would if I was boost charging though.
JE_180
PostPosted: Fri Mar 16, 2012 11:20 am Up
I don't know if you actually NEED to disconnect the battery but I tend to do it when charging any at my house just for safe measure.
fan168
PostPosted: Fri Mar 16, 2012 11:31 am Up
Thanks for the replies, I've only every used the charger once and that was for a completely flat battery in another car. Brought the battery indoors on that occasion as I didn't have a long enough extension lead. The 206 has actually been fine but thought I would charge as a preventative measure.
ta
ukskater01
PostPosted: Fri Mar 16, 2012 1:15 pm Up
At work we trickle charge all the Vito taxis, sometimes we have to put the chargers on max if there really flat. Never removed the batteries from the cabs though
Bummers
PostPosted: Fri Mar 16, 2012 4:51 pm Up
I've never removed a battery when charging it either. Even when totally drained.
2003 206xsi 1.6 16valve
pug206lx
PostPosted: Fri Mar 16, 2012 5:45 pm Up
i dont bother and i charge multiplexed peugeot partners all the time
PostPosted: Sat Mar 17, 2012 6:16 am Up
Faults can take weeks or months to become apparent in electronic systems.
There is a very high risk of cοck-up doing things like that in my experience.
