Online Now [39]:
Visitors: 38
Today: 54424
Total: 117240979
Forums › The Car › 206 Talk › quick question before i head off to the scrappy :)
ashleygilbert92
PostPosted: Sat Mar 10, 2012 7:37 am Up
I'll keep it simple, does anyone know how to remove the drum brake cover?
206 Quiksilver
Bassline_Toad
PostPosted: Sat Mar 10, 2012 7:38 am Up
Got a Haynes? Check there Wink
If not, get one Very Happy
Antknee
PostPosted: Sat Mar 10, 2012 7:45 am Up
Need to take off the hub nut, 32mm if i remember rightly?! could be wrong though. Will also need a punch and hammer to knock out the notch, then hope the bearings aren't stuck, if you have a puller, take it
PostPosted: Sat Mar 10, 2012 7:55 am Up
You should use a NEW hub nut on reassembly & make sure you torque it up correctly!
138Andy
PostPosted: Sat Mar 10, 2012 9:18 am Up
scrappy will rip it off for you if you ask him nice Smile
parkesie
PostPosted: Sat Mar 10, 2012 11:25 am Up
Brake drum from scrap yard i realy wouldnt bother just get a new one theyre cheap enough and youl know its not worn damaged or contaminated.
Signature p**s
twitch169
PostPosted: Sat Mar 10, 2012 3:54 pm Up
I got full drum kit with bearings seals washer nut and drums and shoes both sides for 90 qwid off ebay 180mm drums i think the size is
peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim
