Posted: Sat Mar 10, 2012 3:07 pm |
Some bloody eejit ive had in the passenger seat has caused the roof handle (is grab handle correct name) to come loose, Is it possible to fix it ?
Posted: Sat Mar 10, 2012 3:28 pm |
Tighten the screws?
Posted: Sat Mar 10, 2012 3:29 pm |
should just be screws? was on my MG and cougar
Posted: Sun Mar 11, 2012 5:30 am |
Slide the plastic end-cover to the side and a torx-bolt is revealed.
Posted: Mon Mar 12, 2012 8:47 am |
| V9977 wrote: |
| Slide the plastic end-cover to the side and a torx-bolt is revealed. |
Ah right so they slide over, i tried to move 1 but wouldn't budge but ill give it another go.
Thanks,
Posted: Mon Mar 12, 2012 11:14 am |
Have a go but it might be different on yours.
Don't break anything.
Posted: Wed Mar 21, 2012 8:46 am |
| V9977 wrote: |
Don't break anything. |
Tightend them up the other day, was easy peasy if you sit in the passenger seat to unclip the 2 bits of plastic.
