Online Now [422]:
Visitors: 421
Today: 111156
Total: 154316531
Forums › The Car › 206 Problems › none revving 206
none revving 206
biggypops
PostPosted: Wed Mar 14, 2012 10:02 am Up
Hello all I'm new and a new 206 driver. I have a 51 plate 206 1.1 It idles ok but when I put my foot on the accelerator it coughs and splutters and won't rev. It has had new coil pack cat and today an auto mechanic checked it and found no faults but the car still doe's the same. After I changed the cat it ran great but that was 2 weeks ago
biggypops
Bummers
PostPosted: Wed Mar 14, 2012 10:42 am Up
Injectors/spark plugs/throttle body...
Any fault codes?
2003 206xsi 1.6 16valve
biggypops
PostPosted: Wed Mar 14, 2012 10:51 am Up
No the auto electrician said there was no codes registered has stumped everybody
biggypops
martinius88
PostPosted: Wed Mar 14, 2012 10:54 am Up
my vote is spark plugs, whats in there? Do you know? Get Bosch super 4's
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454
biggypops
PostPosted: Wed Mar 14, 2012 10:57 am Up
but would'not plugs make it miss fire all the time not just when you put your foot on the accelerator ?
biggypops
usher
PostPosted: Wed Mar 14, 2012 2:07 pm Up
see what the air filter looks like i would be clogged with dust etc then as mentioned see how clean the tb is
as you say about the plugs there would be a more obvious problem with the car if plugs were the issue
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
